Bad Vibration at high speed
Hi all,
I have been dealing for a while with a bad vibration at around 70 and up mph. The vibration seems cyclic because sometimes it runs smoother than others I even noticed that sometimes when going down hill itstarts vibrating suddenly and intermintently like: Smooth....prrrrt......prrrrt.....prrrrt...prrrrrrrrrrrrrrrrrt!!!!!
I did the press and release clutch test while running and the vibration changes just a little bit and when speed up and put the tranny in neutral still vibrating very bad. Going troubleshooting this problem I did the following: NEW TIRES BALANCED, NEW WHEEL BEARINGS, NEW FORD RACING 3.55 GEARS AND ALL NEW REAR END BEARINGS, STRAIGHT REAR AXLES, NEW U-JOINTS, STOCK BALANCED DRIVE SHAFT, CORRECT PINION ANGLE....WHAT ELSE??????
So from the yoke back is either new or balanced, I notice some in my opinion excessive lateral play on the yoke which coud be a bad yoke or output shaft but they told me at a transmission shop is not that bad....:shrug:??
I can feel the vibration on my shifter/console area but also on the rear. the flywheel is a new FRPP cast and was balanced bufore I installed it. So basically the only things left to check are the clutch assembly (which is new) and the transmission itself. I noticed that the transmission makes a weird bumping noise when in idle and when the RPM's are on the low side.
What do you guys think? Please post your comments or ideas because I'm getting really frustrated as I have none or very little improvements after all the repairs I've been done.
Nick
Wow it seems like you covered everything. There are a few more things that you could check that may or may not contribute to it. Does the vibration happen at all under 70mph? Does it happen just when revving the engine? Does it change while braking at 70mph and up?
You could check both your motor and trans mounts, it is possible that your yoke on the rear is bent or warpped in some way throwing it off balance. If you can get a dial indicator on the round flange on the yoke and check it for any out of round.
You really have me stumped at well this is odd.
does your trans whine at all? i have this same issue with mine and i have email hanlon motorsports about building my T5 and told them my issues and they said i have a bent balance shaft. im thinking my issue is coming from that
Thanks for posting your ideas and following your suggestions I tell you that reving the engine it runs really smooth new motor mounts and poly transmission mount and cross member bushings, and I already turned all four rotors.
It is hard to determinate if the vibration happens at low speeds too but as I increase the speed from ~ 65 is when I start noticing. The transmission don't whine and shifts smooth. The only abnormality on the transmission in my opinion is the weird bumping noise at low idle, it sounds like excessive backlash or something like that but it definitely comes deep from the tranny. I dial indicated the drive shaft and the ends and it is not a lot of run-out. I also run the car while sitting on wide nice stands and there is a lot of noise right inside the bellhousing.
Believe me I'm totally stumped!!! I have poly front control arms bushings, tubular rear LCA and adjustable UCA. I expected road noise but don't think that's causing the vibration. Or it will????
Please bring all your comments and or suggestions because like you may imagine I'm totally burned out!!! :eek: :jaw:
Nick
At this point looking at that I would have to also point to the clutch assembly or possibly a bent balanced shaft in the tranny even though really unlikely at this point you have pretty much ruled out everything else.
Ok I'm not too sure which one is the balanced shaft. Are you talking about the input or output shaft?? Or is another shaft?? As far as the tie rod end or any other part on the front is i think out of question, but I certainly appreciate your ideas. The steering is nice and quiet at any speed and the vibration happens even with the car sitting on stands. The vibration has to be on the drivetrain somewhere in between the flywheel and the first u-joint. WTF!!! I'm sooooo pist!!!! Any more ideas?
Thanks, Nick
By the way the clutch is a spec-2 and I might have to replace. Does anyone can guide mo on that? I mean which clutch? I've been thinking on dual friction Centerforce, any issueswith that one? I think I read that they need a special flywheel because it just won't work with the cast iron stock one. But before that I must find and correct the vibration, so please keep bringing some more comments, ideas, and or suggestions. I will really appreciate all your help.
Nick
New motor, tranny bushings. New tranny crossmember bushings and the tranny tailhousing bushing was pressed not that long ago although I noticed a bit too much play at the output shaft but again they said at the shop it is normal so I'm going to have to take the tranny down and have them inspected and maybe relace the clutch assembly pilot bearing and even maybe the rear main seal....DAMN IT, IT IS A LOT OF WORK!!!! But I guess I have no other options.
Nick
:DHi all,
I want to share with you some findings and maybe throw a question after.
As a trubleshooting measure I ordered a FRPP aluminum drive shaft from Jegs which blead me 250 bones. A few minutes ago I lifted the ride and let it sit on a set of ramps on the front and a stack of four 2x6 on the rear, I wanted to somehow check the pinion angle and I did it!!! For this I used a digital level and following a few ways posted on the net I decided to give it a shot.
I put the level vertically at the front of the crank pulley and zero the level this way I didn't even have to make any calculations. I then placed the level on a tinny lip of the pinion flange. I say tinny because I didn't remove the drive shaft but I was able to sit the level flat on that little wedge.
My initial reading was between negative 2.3 and 2.5 degrees so I decided to reduce the angle by turning my adjustable upper control arms to approximately minus 1.3 to 1.5 degrees. Locked all the nuts, dropped it and took it for a spin........
SURPRIIIIISE!!!!!!!!!! Most of the vibration is gone!!!!!!!! It rides much, much, much smoother and I'm still going to install the new aluminum shaft.
The new shaft will be here next Wed. but I will double check the pinion angle after I remove the old shaft, this way I will be more certain I have the absolute angle measurement. I'm very happy because I finally see some results after all the troubleshooting as you read at the begining of this thread:D:D:lol::nice:
Now my question for all of you is: What will be the minimum pinion angle I can run???? I've been reading about pinion angle and it is not recommended to have zero angle, and we all can understand that zero angle means straight line and straight line means NO vibration, but also we understand that the suspension defflects whill which will induce positive pinion angle under acceleration(NOT GOOD!!!).
So what will be the minimum pinion angle??? Details of my rear suspension are these: Tubular lower control arms (Polly bushings at the body and solid bushings at the axle) and Adjustable uppers (Solid bushings at the body and polly bushings pressed in the axle ears). I have no idea how much deflection happens under acceleration with this set up, se please if someone has this or similar rear suspension as mine how much negative pinion angle should I use to have the least drivetrain vibration.
Thanks a lot for the help, Nick
Hi Nick....
Glad you got your vibration issue resolved. It seems our 'stangs have plenty different ones to go around :shrug:
I have a 99GT with the auto, 4r70w, tranny. I am just to the point where you just last posted. However; the only thing left for me to do is get that tailshaft bushing replaced. I have a new FRPP alum. with new auto slip yoke ready to go in once that bushing gets changed out, and that should take care of my annoying vibration.
I too adjusted my pinion angle to around -1.5 and it elimintated alot, but I can still hear it ever so slightly.
Not sure what your T-5 specs are, but at least for my auto, the ID of the bushing is 1.602 and the slip yoke OD is 1.598. that leaves .004 That isn't much, and I can move my slip yoke a bit more than .004. My question is where did you bring the tailshaft to get the bushing pressed out/in??? Would a transmission place like aamco be able to do that? or any garage with a press????
Also thanks for posting about your pinion angle change...that relieved my worries about my adjustment.
Nancy
On a side note for those with automatic transmissions. (at least the 4r70W)..Ford doesn't just sell that bushing anymore. They say is not a servicable item and you have to get the whole tailshaft housing replaced:fuss:($168 just for the part + labor etc.....):jaw: That's outrageous for a $5 part that is replaceable.
Thanks njoliver..I wish I had a press or even a friend with a press I would do it myself. Stopped by aamco on the way home and they said it would be about $70 bucks.....I'll have to do it next week once my parts come in.
