I am getting a bad vibration from the engine in my gt...i replaced the worn motor and tranny mounts...but the vibration is worse now due to the stiffer mounts.....i was told by an "expert" that i have a worn out cam....but i dont hear any cam noise....compression checks good, and i just put new plugs,wires, cap, rotor on. harmonic balancer seems to have very little run out..........HELP GUYS, ANY IDEAS???
Engine does not miss or anything...but vibrates badly at idle,(it shakes the entire car).....when driving it seems to vibrate less, except when you are comming to a stop and the engine rpm drops to around 1000 rpm then it vibrates badly again..PLEASE HELP....I NEED TO KNOW QUICKLY IF I SHOULD BUY A LONGBLOCK OR IF IT MAY BE A SIMPLY SOMETHING STUPID THAT CAN BE REPLACED.....ANYONE HAVE A GOOD USED 302 FROM 94-95...OR KNOW WHERE I CAN GET A GOOD LONGBLOCK?....THANX IN ADVANCE!!!
