bad vibrations
im getting a really bad vibration at about 60 mph i had all 4 tires blanced checked my motor mounts and made sure my drivline was still balanced. what else could it be. it does it not matter what gear your in and it still does it with the clutch in. im stumped on this one guys plz help.
thx in advance
if it does it in any gear, does it also do it in neutral? dont forget the harmonic balancer.
good luck.
if it does it in neutral (and stationary), it is not the DS. i stand by my first post as something to check.
good luck.
You've had your driveshaft checked by a driveline shop? I read your first post and wasn't clear on that.....If not you may want to do so. Also if you haven't had it out and back in recently you may want to make sure you ds bolts aren't loose
