bad whining sound when accelerating
  • Thread starter Thread starter greenstang1313
  • Start date Start date Feb 19, 2006
G
greenstang1313
158
Chelmsford, MA
Feb 19, 2006
  • Feb 19, 2006
I have a 94 Cobra and when I accelerate there is a really annoying and high pitched whining sound. If I had to guess I'd say its probably either the clutch or the gears but I'm not sure so I'm posting here. I really don't know how to describe the sound other than just "whining" so any help would be apprectiated.
-Craig
69Rcode_Mach1
1,473
Salt Lake City, Utah
Feb 19, 2006
  • Feb 19, 2006
Did you buy the car like that or did it one day start doing that.
I
Iand
50
Kelowna, BC
Feb 19, 2006
  • Feb 19, 2006
does it whine in every gear or just a certain one?
6SpeedLX
100
Mass
Feb 19, 2006
  • Feb 19, 2006
check under the hood, maybe theres a Kenne Bell blower under there you dont know about??
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Feb 19, 2006
  • Feb 19, 2006
Yeah, mine kinda has the whinning sound too
Usually a whinning sound is the tranny (especially if its particulary bad in a certain gear)... Good luck man.
mustangramair
326
Iowa
Feb 19, 2006
  • Feb 19, 2006
Did you recently get a new belt, that happened to me because they gave me the wrong sized belt. I got the right belt and the whining under acceleration stopped. I know it's simple but i thought i would throw it out there.
I
IntenseBlue
946
  • Feb 19, 2006
You'd hear gear whine all the time. Bad tensioner pulley?
G
greenstang1313
158
Chelmsford, MA
Feb 19, 2006
  • Feb 19, 2006
every gear
ughh i dont know what to do
poneypower89
Dec 6, 2004
Feb 19, 2006
  • Feb 19, 2006
True, but if the sound was progressively worse in a certain gear, that would point to tranny. ya know?
But if it sounds exactly the same in every gear... i would look at the pulley system... does it do it revving in nuetral?
HISSIN50
34
129
Feb 19, 2006
#10
  • Feb 19, 2006
  • #10
This is the best question so far. You need to find out whether it is engine or drivetrain related.
Good luck.
speadfreak
118
#11
  • Feb 19, 2006
  • #11
One of mine used to do that. Sounded like a power steering pump low on fluid, underneith the car..........ended up being the throwout bearing.
G
greenstang1313
158
Chelmsford, MA
Feb 21, 2006
#12
  • Feb 21, 2006
  • #12
Ok guys, I'm back. I was playing around with the car last night and I figured out that the whining only DOES occur in 1st, 2nd, and 3rd gears. Also, it does NOT occur when the car is in neutral. Is there a chance that maybe its just a lose belt or something?
Its really aggravating because my car runs so beautifully other than this annoying whining.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 21, 2006
#13
  • Feb 21, 2006
  • #13
Only doing it in certain gears points to a transmission issue. Change your fluid ASAP, and loook for signs of metal suspended in the old fluid. Once they get to this point, the damage is usually done already, and the whine is caused by excessive clearances between gears and bearings.
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
