BADDD WHEEL HOP NEED HELP!!
  • Thread starter Thread starter lxwants12's
  • Start date Start date Mar 11, 2006
lxwants12's
506
  • Mar 11, 2006
I have pretty bad wheel hop....i installed d&d uppers and lowers....eibach springs,comp engineerring adjust. shocks set at 50/50....the car never wheel hop b4 and now it does it when im doing a burnout....im not sure what it is cause i installed everything all at once...the uppers where really hard to work with i had to move the rearend around alot to make them work and fit...should i go back to stock uppers?? has any1 had experience with d&d uppers and lowers?
LordMustangGT
118
Port Orchard, WA
Mar 11, 2006
  • Mar 11, 2006
if anything i shouldn't do that at all. that is really werid.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Mar 11, 2006
  • Mar 11, 2006
Are they adjustable?
Get everything square and try again.
lxwants12's
506
  • Mar 11, 2006
no not adjustable...but i didnt like the way everything went together...it wasnt a smooth install everything seem off after installing the uppers...even when i went to put the sway bar back on....it was a MISSION!!! it would fit until i managed to bend it closer together
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Mar 11, 2006
  • Mar 11, 2006
Sure the uppers aint lefts and rights?
lxwants12's
506
  • Mar 11, 2006
im gonna tear it all apart agan tomorrow...i did double check that b4 i put them on though and they look identical...im thinkin its the brand..maybe i should have got the ford racing uppers i heard they are really good and retail stock size...these uppers seemed a lil shorter
lxwants12's
506
  • Mar 12, 2006
the quad shocks are missing!!!and so are the mounts which connect to the body..i know i can get the shocks at autozone but whatbout the mounts??
T
tbi92rs
69
Louisville, KY
Mar 12, 2006
  • Mar 12, 2006
You dont need quadshocks.....I dont have them and wont ever use them.
Sounds like pinion angle is off pretty good. they are adjustable and therefore, you need your pinion angle adjusted to correct specs.
I suggest talking to a frame shop and see if they can do it for you. I know a local KY speed shop (Speedy's) does that. Might wanna check a good speed shop and see if they'll do it.
That sounds liek the source of your problems.
I have ProFab upper/lowers, Monroe sensaTrac shocks, stock springs and no quadshocks and I didnt get any wheelhop.....I just had excessive movement in my rearend because of the stock, crumbling rearend housing bushings.....they dont go well with my solid bushing control arms
JBeezy53
559
Sacramento, Ca
Mar 12, 2006
  • Mar 12, 2006
Everytime I have changed upper or lower arms its always taken a little time to get the rear end at the right angle/position for a certain bolt. Also you shouldn't need the quads. I have Mac lowers and stock upper and I have no wheel hop.
lxwants12's
506
#10
  • Mar 12, 2006
  • #10
how can i adjust the angle?? what should it be at? could that explain the drivetrain vibe i have been getting and the reason i broke something in the rear today? i hae been driving it like this for about a year
79lxSBF
11
#11
  • Mar 15, 2006
  • #11
That's funny. I just did steeda uppers and lowers over the weekend and took it out for a test burnout and broke my rear too. I was getting crazy wheel hop in my burnout then I went to launch and something wasn't right. Looked under the rear and saw all the gear oil coming out. My uppers are adjustable also so I guess they need to be adjusted.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 16, 2006
#12
  • Mar 16, 2006
  • #12
i put lakewood's traction action set up on my car. i got no wheel hop i love em.
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
