BADDD WHEEL HOP NEED HELP!!
lxwants12's
506
I have pretty bad wheel hop....i installed d&d uppers and lowers....eibach springs,comp engineerring adjust. shocks set at 50/50....the car never wheel hop b4 and now it does it when im doing a burnout....im not sure what it is cause i installed everything all at once...the uppers where really hard to work with i had to move the rearend around alot to make them work and fit...should i go back to stock uppers?? has any1 had experience with d&d uppers and lowers?
no not adjustable...but i didnt like the way everything went together...it wasnt a smooth install everything seem off after installing the uppers...even when i went to put the sway bar back on....it was a MISSION!!! it would fit until i managed to bend it closer together
Sure the uppers aint lefts and rights?
im gonna tear it all apart agan tomorrow...i did double check that b4 i put them on though and they look identical...im thinkin its the brand..maybe i should have got the ford racing uppers i heard they are really good and retail stock size...these uppers seemed a lil shorter
You dont need quadshocks.....I dont have them and wont ever use them.
Sounds like pinion angle is off pretty good. they are adjustable and therefore, you need your pinion angle adjusted to correct specs.
I suggest talking to a frame shop and see if they can do it for you. I know a local KY speed shop (Speedy's) does that. Might wanna check a good speed shop and see if they'll do it.
That sounds liek the source of your problems.
I have ProFab upper/lowers, Monroe sensaTrac shocks, stock springs and no quadshocks and I didnt get any wheelhop.....I just had excessive movement in my rearend because of the stock, crumbling rearend housing bushings.....they dont go well with my solid bushing control arms :(
Everytime I have changed upper or lower arms its always taken a little time to get the rear end at the right angle/position for a certain bolt. Also you shouldn't need the quads. I have Mac lowers and stock upper and I have no wheel hop.
how can i adjust the angle?? what should it be at? could that explain the drivetrain vibe i have been getting and the reason i broke something in the rear today? i hae been driving it like this for about a year
That's funny. I just did steeda uppers and lowers over the weekend and took it out for a test burnout and broke my rear too. I was getting crazy wheel hop in my burnout then I went to launch and something wasn't right. Looked under the rear and saw all the gear oil coming out. My uppers are adjustable also so I guess they need to be adjusted.
