Baer Tracker with Granada Spindles
  • Thread starter Thread starter SNAKEPILOT
  • Start date Start date Apr 27, 2008
SNAKEPILOT
112
  • Apr 27, 2008
Granada spindles use tie rods with a different taper than 70-73 Mustang spindles. Baer doesn't make a Tracker for Granadas. Anyone using the Baer 70-73 Tracker on their Granada spindles?
enferno
418
  • Apr 28, 2008
the thread size for the tie rods should be the same 65-73 with v-8
chepsk8
2,203
Easton, PA
Apr 28, 2008
  • Apr 28, 2008
Aren't the Granada holes a little bigger? I used the 74-78 MII ends, but I had the Rack & Pinion conversion.
Find an old MOOG front end parts catalogue, and compare tapers & diameters.
SNAKEPILOT
112
  • Apr 28, 2008
Theads are the same but the taper of the spindle pin is definitely different for 65-69 and 70-73. Granada tie rods are different PNs than 70-73s. My search of the web says they are different but you can use the Baer Tracker for 70-73?
My other option is Global West. Their kit comes with a big drill bit and you make the spindle fit their tie rod.
It's a beefy spherical bearing that is unlikely to go bad but I am concerned about locking myself into that one style of tie rod.
Though I suppose if I "broke" a Baer Tracker, I wouldn't be picking up a replacement at NAPA or AutoZone either. Although if I was say driving cross country I could swap out the Trackers for regular tie rods, re-align it and keep going. Then again, have you ever seen a tie rod fail? They just get sloppy and "should" be replaced. Not a stuck in the desert type of problem.
Excessive toe in after sn95 spindle swap
  • cnorman31
  • Feb 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2025
cnorman31
T
New here, just saying hi.
  • Tank Mechanic
  • Nov 1, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 2, 2025
nickyb
Aluminum non-metric brake calipers for use on 11" granada rotors?
  • Blue Thunder
  • May 21, 2024
1974 - 1978 Mustang II Talk & Tech Jul 24, 2024
65ShelbyClone
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
