Well i've been reading on the board that the stock balancer is of questionable quality. I've noticed my motor vibrates a bit (vibrates with clutch in). The bottom end is all stock so unless the factory balance is terrible it should be within balance. So the balancer is suspect, although it doesn't show signs of coming apart, the timing marks seem to correspond correctly...
My question is are these motors internally balanced? IE is the balancer and flywheel neutrally balanced? What are my options for aftermarket balancers? I'm assuming earlier 302 stuff doesn't interchange?
