Balancer seal saver....
Anyone ever use one?
I had to pull my rad yesterday due to a burst seam and thought I should pull my waterpump and thermostat for inspection. Then I thought maybe I should pull the timing cover to inspect the timing set and fix that pesky leak behind the balancer. Well, the seal is dried and cracked in about five places and there is a groove worn around the mating surface on the balancer. My neighbor said I should look into a seal safer kit which consists of a thin sleeve to put over the balancer shaft and a tool to drive it on for around fifty bucks. Does this work for the long run, or should I put out the extra cash for a new balancer? How much does a balancer cost anyway?
Oh, and the timing set was so loose it looked like I was seconds away from catastrophic engine failure.
I have used them in the past. They do work for a while. They are expensive and not always easy to install. You can ruin one real quick. Why not just invest in a new balancer. You can get a budget one from Summit for under $100 delivered.
Well I went with the seal saver. I didn't get the kit, I just bought the sleeve with locktite for thirteen bucks and drove it on with a mandrel. Looks like it did the trick.
I also put a new timing set in and cleaned and painted all the covers, brackets and water pump.
The one piece oil pan gasket I recently put in sure made things easier. You don't have to drop the pan or use those hokey gasket ends that come with the timing cover gasket kit.
Are you talking about a Speedy Sleeve? If so, we use them all the time at the machine shop I work at and they work fine. FYI, there are also offset seals available that work well, too. Ask any decent automotive machine shop about them.
