ball joints which ones
  • Thread starter Thread starter stevesLX
  • Start date Start date Feb 16, 2007
stevesLX
373
cincinnati
Feb 16, 2007
  • Feb 16, 2007
I bought some TRW ball joints today and they are sealed. I bought the ones for a 94 GT since I have 94-95 spindles. My control arms are for a 89. Anyways these things just seemed like they were to easy to press into the hole on the control arm. I shoved almost 3/4 of it in there and had to press the rest of it. Then the darn nut would only go down a couple of threads and kept hanging up. The threads looked fine. So I pulled the other one out the box and tried threading that nut on that one and it did the same thing. So I guess I will be returning these. Once the nut hangs up the whole threaded shaft turns and theres nowhere to grab it and stop it while you thread the nut down. These also had just a regular nut and no cotter pin or castle nut. I looked at the TRW's for a 89 and the shaft is longer and it has a grease fitting and a castle nut and cotter pin. So any suggestions would be great. These ball joints seemed awful sloppy is that normal. Like I had to hold the spindle up when I tried to put the one on before the nut deal happened. Now I did still have the rotor attached so that added some weight to it. My old one I popped out seemed a lot stiffer.
superhuaman
907
Harrisburg, PA
Feb 17, 2007
  • Feb 17, 2007
what spindles are you using? you can use 89 b/j with a 94 spindle but not the other way around. also, most new ball joints with grease fittings must be greased. they usually dont come that way.
Snikt89GT
264
Deland, Florida
Feb 17, 2007
  • Feb 17, 2007
Use the 94 ball joints so you don't have to mess with the crappy cotter pin or spacer. Works fine as long as you have 94+ spindles
superhuaman
907
Harrisburg, PA
Feb 17, 2007
  • Feb 17, 2007
yeah...you have to kind of push the spindle down onto the b/j and the friction between the two will keep the b/j from spinning, while you zap the b/j nut on with an impact gun
E
Steering stops not connecting
  • ELP1
  • Apr 25, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 25, 2026
ELP1
E
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
