Ballast resistor question
  • Thread starter Thread starter limey66
  • Start date Start date Oct 30, 2004
L
limey66
408
Northampton, England
Oct 30, 2004
  • Oct 30, 2004
I have a Crane Cams PS20 coil ready to go in my 289 c code '66. I'm also installing a Crane XR-i electronic ignition module at the same time. My question is this:
How do I tell if a coil has an internal ballast resistance?
The Crane XR-i instructions say if I measure the resistance between the '+' and '-' terminals of the coil and it is between 3 and 4 Ohms it's got an internal ballast resistance. It has a 4 ohm resistance, BUT in the box with the coil is a nice ceramic resistor that has a 9 Ohm resistance - why would I need that? The Ford wiring diagram says that the ballast resistance in the harness is 1.3-1.4 Ohms, so 9 Ohms is overkill.
Help.
66HertzClone
428
Central New Jersey
Oct 30, 2004
  • Oct 30, 2004
Mustangs did not have a resistor built in the coil, they have resistance wire. It is usually covered with a woven fabric and is located under the dash. You can verify this by checking the voltage at the positive side of the coil.
L
limey66
408
Oct 30, 2004
  • Oct 30, 2004
Ah, yes, but mine has been pulled about and came to me part re-wired with no ballast resistor or coil. I got the Crane coil but I don't know if it has a built-in resistance.
Thanks though.
Red Barchetta
761
Behind the Orange Curtain
Oct 31, 2004
  • Oct 31, 2004
Help.
The only thing I'd double check is to see if that resistor says 9 or .9. Is there a part number on the resistor? Maybe then you could look it up to get the correct value as you're right, 9 ohms is overkill. Or, you could always give Crane a call, they should have the answer.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Oct 31, 2004
  • Oct 31, 2004
A resistance wire or a ballast is ONLY used in a point distributor. so if you changed to a aftermarket or OEM electronic type distributor use full voltage only or you will not get the full (hot spark)
whwright
150
Oklahoma City
Oct 31, 2004
  • Oct 31, 2004
Some electronic distributors require a ballast resistor, most don't. Sometimes a distributor will require a ballast resistor with certain coils, but not with other coils.
Bottom line: follow the directions.
Wayne.
L
limey66
408
Nov 1, 2004
  • Nov 1, 2004
Thanks guys.
Mopping up the various points above; I measured the additional supplied resistor as it has no markings on it at all, and that measures 9 Ohms, the car doesn't run so I can't check the voltage , the Crane XR-i kit is supposed to run with the factory ballast resistor or a ballasted coil - I don't know what I got...
In a nutshell, does a 4 Ohm coil sound like it has an internal ballast?
rbohm
6,698
550
204
tucson,az
Nov 1, 2004
  • Nov 1, 2004
i think if you check the instructions that come with the coil, you will find that crane says you have to use the ballast resistor that comes with the coil, EVEN IF you have a factory ballast resistor, or resistance wire. use the ballast resistor.
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Resolved 1989 Mustang GT no spark, no trigger pump relay
  • Nine Finger Wrenching
  • Nov 26, 2023
4K
Fox 5.0 Mustang Tech Nov 30, 2023
  • dan50
  • Jul 18, 2026
dan50
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
