Basic Circuit breaker question!
Kdubslugga
1,515
Akron, OH
I just took out my vortech t rex pump, installed an Anderson Big pump. I have it installed and pump operates fine however the instructions call for a circuit breaker to be added, The instructions for the relay and circuit breaker suck, so where should i install the circuit breaker? The way i have it wired is as follows. The relay has 4 tabs. 1 goes straight to pump, 2 goes straight to ground, 3 taps into stock fuel pump harness, 4 runs straight from relay to positive battery terminal in the trunk. Im assuming i should cut that last wire and insert the circuit breaker here correct??
