  • SN95 4.6L Mustang Tech
Bassani header and accufab plenum Qs..
  • Thread starter Thread starter turbokid
  • Start date Start date Mar 20, 2004
T
turbokid
113
  • Mar 20, 2004
i dont know what to go with... a mid length bassani headers that are ceramic coated or an accufab plenum. I know there is a price gap between these two mods but i still want your opinions regardless of the price (just opinions based on performances) Also what is the difference between long tube headers and just mid size headers????
Red35th
609
Houston, TX
Mar 21, 2004
  • Mar 21, 2004
Well, assuming that you have the correct mid pipe (X or H) to fit the midlength headers I'd go with them. According to Bassani, they are the optimal length for hp and torque. I've only seen them dynoed in one mag and they outgained MAC longtubes by a fair margin.
If you don't have a bigger throttle body, the accufab plenum isn't worth much. A switch to midlengths and a different mid-pipe (required) would be a pretty penny, into the 700s I'd wager. I've never seen the Accufab dyno over 12hp, and that's with a new throttlebody.
Basically they are both solid mods, how much do you want to spend to go fast? I'd take the bigger hp gain if I had the cash. A plenum w/o throttle body is a small gain.
T
turbokid
113
  • Mar 21, 2004
thanx, i dont know if my xpipe will fit the bassani headers.. but my whole exhaust system is from bassani including my xpipe and catz.
9
97 Stang GT
33
  • Mar 21, 2004
Your bassani x will fit just fine.
03-s281
421
Stangville,TN
Mar 21, 2004
  • Mar 21, 2004
So does this mean bassani mid lengths will fit a upr o/r x-pipe?
I am assuming his catted x is bolted to the stock manifolds.
quiksilver98
251
Orange County So.Cal
Mar 21, 2004
  • Mar 21, 2004
The Bassani Mid-Length Headers $550 ''ceramic coated,'' will only fit Bassani 03 Cobra X-pipe. You will need to customize your current X-pipe to make it fit about a $150 jobber.As for power gains it did add lots of torque but horsepower wise it felt like 12-18 rwhp.I did the Header job last so...I it felt it with all the mods I listed.If you're looking for some real power go with Longtubes.If I could start all over I would sell my existing X-pipe and I probably would have went with Longtubes and Dr Gas X-pipe.But the real pain is getting them installed for a decent price.Depending on the places you take them to be installed.Some places would not even do it because it's not smog legal, unless you can do it yourself.
T
turbokid
113
  • Mar 21, 2004
so if i have a 2000 gt with a bassani xpipe the mid length bassani headers will not fit???
stage8
  • Mar 21, 2004
If you order them tell the person you need a set for catted X pipe.They will send two pieces of pipe that fit right before the cats.I would think you would be able to cut your pipe and make it work with no problems. I just got a custom H pipe made for mine.Sounds great and a great product.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
BBK 351w headers
  • fully
  • Jan 30, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 4, 2025
dcm0123
D
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
