  • SN95 4.6L Mustang Tech
Bassani Headers Install
  • Thread starter Thread starter djk8705
  • Start date Start date Sep 30, 2004
djk8705
154
Fairfax, Va
Sep 30, 2004
  • Sep 30, 2004
Hey guys, I am getting them in the mail tommro and need to know the best way to install these. These are the midlengths so im not sure if you need to do everything as if it were a LT install. Thanks
-Dan
djk8705
154
Fairfax, Va
Sep 30, 2004
  • Sep 30, 2004
Sorry I left this out but This is for a 2004 GT
Thanks
djk8705
154
Fairfax, Va
Oct 1, 2004
  • Oct 1, 2004
TTT
nickthegenius
1,631
Elwood, IN
Oct 1, 2004
  • Oct 1, 2004
djk8705 said:
TTT
I would treat any header install the same way. Using this guide will give you the most room to work with.
http://www.fnsweet.com/garage/lt_install/index.shtml
stangman
2,690
10
69
in a 3 bed, 2 bath
Oct 1, 2004
  • Oct 1, 2004
definately take the time to drop the k-member. it may seem like more work, but trust me, it ends up saving a lot of time
WhiteDevil69
518
Tucson, AZ
Oct 1, 2004
  • Oct 1, 2004
Sorry to jack the thread but what about with the BBK Tuned Length Shorties? Think its worth taking the springs out and all those extras steps as well?? The only reason I would really rather not is, I just got through putting them in this last weekend.. I thought Shorties should be alot easier to install, think I can skip any of these steps?
WhiteDevil69
518
Tucson, AZ
Oct 1, 2004
  • Oct 1, 2004
nickthegenius said:
After reading some posts at Modular Depot about the BBKs, I would drop the K-member. The way the tubes bend and wrap around causes some of the bolt holes to be really hard to access. Accessing them with the K-member in on a set of headers with accessible holes is bad enough, let alone with a set that makes it hard to get to the holes.
good deal, I will for sure then, just to make it easier even if it is possible without. Now for the gaskets they came with... First off they were all warped and bent when i got them. on one there is a little crease where it was bent, didn't crack it or anything, but there is that noticable crease. Think these are worth using, even if they were perfect? I have heard that the stock gaskets are probly better, mainly becuase its an 03 too so they are basicly new.. what do you think?
nickthegenius
1,631
Elwood, IN
Oct 1, 2004
  • Oct 1, 2004
C
cgrant
132
  • Oct 1, 2004
when I did mine we didnt take out the K member...
we used a jack to lift/lower the engine for a few of the pipes.
Was a struggle but it got done
C
Engine 01 gt
  • Carboni
  • Jun 28, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
nickyb
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
LT headers/ CEL misfire
  • Starxk
  • Jul 28, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jul 28, 2025
