Batt Cut Switch -Keyed Question
so, the strip doesn't allowed *keyed cut switches... correct?
what if you have a keyed switch, drill a hole while its in, so that you could insert a pin to keep the key in... would this be an option???
im asking under the assumption you can't have a keyed cut switch because it could come out, or in emergency be a pain to get it in quickly instead of it being there and flipping it.
just a thought... also the keyed ones are alot cheaper than some of the other cut switches...
