  • 1994 - 1995 Specific Tech
Battery cables for relocation. And Other Questions???
  • Thread starter Thread starter Bosko5.0
  • Start date Start date Nov 30, 2007
First Prev 2 of 2
gcomfx.com
3,690
Republic, MO
Dec 13, 2007
#21
  • Dec 13, 2007
  • #21
Bosko5.0 said:
Well since no one responded to my PM'S
I decided to go with 1/0 cable I got 15ft pos. and 5ft of neg. and another #4 of neg to run from the battery ground(chassis) to the front either block or stock battery grund. And I also and using the connectors that were reccomended by matt.
There is a fancy little tool used for those connectors. I used the same ones and a buddy had the tool, so I borrowed it. You basically put the connector and wire in it, then hit it with a BFH.
Bosko5.0
1,067
longwood, FL
Dec 13, 2007
#22
  • Dec 13, 2007
  • #22
I was going to solder them in.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 14, 2007
#23
  • Dec 14, 2007
  • #23
Solder them. Heat the connector with a propane torch, fill it with solder, and shove the wire into the hot solder. Better connection, less resistance.
gcomfx.com
3,690
Republic, MO
Dec 14, 2007
#24
  • Dec 14, 2007
  • #24
Yeah, yeah... there's that way too.
BTW - I would heat the wire just a bit as well.
I had one connection I had to put on after the wire was run. Makes it a bit tougher when you don't have a lot of slack, so order extra wire if you can afford it.
RFink
Melrose<MA
Dec 31, 2007
#25
  • Dec 31, 2007
  • #25
There's a chart in ford fuel injection , look under the Tech Articles.
Bosko5.0
1,067
longwood, FL
Dec 31, 2007
#26
  • Dec 31, 2007
  • #26
thanks for that info I'll look.
First Prev 2 of 2
C
No Crank--have power(accessories)
  • chazmanaz
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 17, 2025
chazmanaz
C
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
