battery location
4.6rx7
48
i own an 88 tbird but this forum is way better than the tbird forums on a battery relocation do you fuse the main wire from front to back and if so do you put it in the front or back i plan on fusing my 170 amp alt to starter relay than run wire from starter relay to rear battery
You cant really fuse the starter wire. What you can do to make it more safe is to move the starter solenoid so that the huge wire is not hot the entire time. You'll need to extend a feed to power all of your accessories and you can fuse that one at the battery and at the alternator.
