  • 1994 - 1995 Specific Tech
Battery Relocation ?'s
  • Thread starter Thread starter SeventyMach1
  • Start date Start date Mar 26, 2006
1 of 2 Next Last
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Mar 26, 2006
  • Mar 26, 2006
Okay ... I just got a red top Optima (thanks for the help Ernan ... the 34/78 is great). I notched the factory tray (which is now busted up where the bottom bolt goes). I don't have a "hold down" yet .... and I really needed to extend the cables since the posts are narrower.
So now I'm considering putting it in the trunk. I don't feel like paying $190 for a relocation kit.
1.) Is it true that you don't need a battery box with these batteries?
2.) What exactly all do I need to mount & wire this thing into the trunk?
SM0k3
580
La Palma, California
Mar 26, 2006
  • Mar 26, 2006
interested in this too.....subscribing.
M
Monsterbishi
107
Christchurch, New Zealand
Mar 26, 2006
  • Mar 26, 2006
ok, the general rule is that if the battery is a gel-cell type/SLA(sealed lead acid) - then you do not require a closed battery box since there is nowhere for battery acid to leak from.
If you move it to the trunk, keep in mind the extra weight gained from the cable too.
Edit: If you mount the battery in the trunk without a box, check with your local laws as to the standard of bolt/strap required to hold it down the the body.
HISSIN50
34
129
Mar 26, 2006
  • Mar 26, 2006
Justin, if you wanted, you could use a marine battery box (under 10 bucks at wally mart). You could trim-it-out nicely I bet (cover it in vinyl, red crushed velvet velour, etc).
Just an option.
Good luck mang.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Mar 26, 2006
  • Mar 26, 2006
That's a good idea JT .... Thanks, I'll see what I can find & fab up.
Now for the wiring part .... anyone know what I need to get? And a how-to would be great!
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Mar 26, 2006
  • Mar 26, 2006
I would not take a chance with it back there...ALWAYS err on the side of caution. Good choice with the battery selection.
RC
ES Stangin
132
Erie, Pa
Mar 26, 2006
  • Mar 26, 2006
I just installed the Summit battery relocation kit in my trunk. I have an Optima, and wasnt worried about IHRA/NHRA rules so the Summit kit worked well, since it came with all of the cable, ends, box, etc. The only thing is that I have to figure out a way to tie the battery down, since the supplied bracket doesnt fit along the sides of my Optima while in the box, and I don't trust the box the keep the battery in.
bimmertech
1,123
merriam, ks
Mar 26, 2006
  • Mar 26, 2006
i bought the taylor box with 1 gauge cable and vented box for $120. only way to fly.
95strokerPSU
986
Sacramento from Philly
Mar 26, 2006
  • Mar 26, 2006
I bought this battery hold down and will just be going to a welding supply store and picking up some 1/0 cable and lugs to put it in the trunk.
95cobraguy
637
11
Concord, NC by way of LI, NY
Mar 26, 2006
#10
  • Mar 26, 2006
  • #10
i use the same optima battery in a upr box in the trunk. wiring is straightforward, i ran the positive from the trunk, under all carpet and rear sear delete, and through the hole in the firewall where the cruise control vacuum hose was (deleted cruise control also) and connected it right to the underhood fuse box. for the ground i used the factory ground cable, its a double ground. the big ground i ran through a hole in the trunk an bolted it to a bolt near the quad schock bracket. the small one i just grounded to the stud that runs through the trunk that mounts the box. i have an almost brand new battery tray if anyone needs it.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Mar 26, 2006
#11
  • Mar 26, 2006
  • #11
Thanks for the input guys.
Did any of you have to drop the gas tank for the install?
SM0k3
580
Mar 26, 2006
#12
  • Mar 26, 2006
  • #12
might be doing this soon. Anyone know what gauge the positive wire is?, need to buy that and the ends.
95cobraguy
637
11
Mar 26, 2006
#13
  • Mar 26, 2006
  • #13
no need to drop gas tank, just need to be careful when drilling the holes in the trunk. the upr kit i bought came with all the cables, i think it came with 4 gauge wire. i ended up using the factory ground cable and modified it to make it work.
Hoytster
I don't dare do that to my Knob
20+ Year Stangneter
Dec 30, 2002
1,069
700
164
Cornwall, PA
Mar 26, 2006
#14
  • Mar 26, 2006
  • #14
I know the summit kit I bought came with 2 guage cable. I wouldn' go any smaller than that for the length of cable needed to go from the trunk to the engine bay.
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 26, 2006
#15
  • Mar 26, 2006
  • #15
Local laws might also stay it's fully illegal to put the battery in trunk, no matter what
SM0k3
580
Mar 26, 2006
#16
  • Mar 26, 2006
  • #16
word, technically anything changed much from the way it came from the factory isnt legal, but i dont think anyone is that much of a dick haha
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 26, 2006
#17
  • Mar 26, 2006
  • #17
so true
what NON-auto technical people (lawmakers) are trying to throw at everyone is that battery = spark and spark closer to a gas tank is bad
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Mar 26, 2006
#18
  • Mar 26, 2006
  • #18
Haha ... I better relocate my coil pack to the interior console .... it's too close to the fuel lines in the engine bay, lol.
go-stang5.0
2,244
Glenview,Il
Mar 28, 2006
#19
  • Mar 28, 2006
  • #19
I gott the jegs or summit kit back when they just came out and were selling it for $25 bux. I thought it was a sweet deal. I mean you cant even get 20' of 2 ga. cable for that much now a days. Although I dont really like the plastic box, I'm still running it and I road raced with it once so far however they didn't like it too much at tech. I need to get a nice sturdy metal box. But yea I ran the main fuse box wire to the starter and the wire from the battery to the starter underneath the car through a hole in the trunk. Been working good for a while now.
gustang818
48
#20
  • Mar 28, 2006
  • #20
I got the Summit kit and didn't like the plastic box much either. The rest of the kit worked great. I had a piece of thin guage channel iron laying around that I notched, bent and welded into a battery tray. I welded the studs from the kit onto it, painted it up and bolted it into the trunk. I would (and did) drop the tank before doing any drilling through the trunk floor pan. The tank is pretty tight to the pan as the previous owner of my car found out. He put three sheet metal screws through the tank when installing his amp in the trunk.
EDIT: I have an Optima battery also. I wouldn't use a wet cell in the trunk unless it was fully enclosed and vented.
1 of 2 Next Last
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
T
2008 GT Parasitic drain - sjb
  • turcotjs
  • Aug 1, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 1, 2025
turcotjs
T
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
C
Wiring a battery relocated to trunk
  • Ch3No2
  • Jan 24, 2023
4K
Fox 5.0 Mustang Tech Jan 25, 2023
AeroCoupe
