BBK INTAKE ON 5.0 ?
  • Thread starter Thread starter 89blackpearl
  • Start date Start date Apr 3, 2007
89blackpearl
Long Beach
Apr 3, 2007
  • Apr 3, 2007
Hello peeps im having a serious problem with my 89 h-back. So im trying to diagnose the problem. I have a few simple questions. Do you have a bbk fenderwall intake on your stang? And does your engine begin to stumble when you disconnect the mass air flow sensor. when i remove the mass air flow sensor on my mustang,the vehicle stays on, and doesnt even stumble (more than it already is) Is this normal or is the car supposed to shut off. Thanks for the help peeps. Please reply...i need all the help i can get.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 4, 2007
  • Apr 4, 2007
The car will continue to run - the EEC substitutes a calculated fuel curve after reading all the sensors. Don't run it that way routinely.......
89blackpearl
Long Beach
Apr 4, 2007
  • Apr 4, 2007
Question Bro!
I have a 1989 hatch 5.0, when the car is under load it stumbles pretty bad. It feels like it has a bad sparkplug wire, but it does not. They're brand spankin' new. However, when I get to 2000 rpm in 3rd gear (automatic) the car runs good as new. I've been having this problem for about 3 months not, and i can figure it out. Thanx for your time. Hopefully you can throw some hints at me.
Chris
C
C6AE
145
Ma.
Apr 4, 2007
  • Apr 4, 2007
Codes?
JChalfan
551
Bellevue, WA
Apr 4, 2007
  • Apr 4, 2007
C6AE said:
Codes?
Yeah, always check for codes first. It's possible to have stored codes without the check engine light being on. Code readers are pretty cheap ($30), or there's a free method that's detailed in quite a few posts on here. jrichker's got a good write-up.
Do a search for "check codes" or "pull codes" and you should find the write-up.
Jeff
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 4, 2007
  • Apr 4, 2007
yes, it's always good to start with the codes..........
P
PJB
131
Rotterdam, NY
Apr 4, 2007
  • Apr 4, 2007
Ive got the BBK fenderwell CAI and my car runs fine.
Check for a vacuum leak. That might be your problem.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
