Bbk Long Tube Headers Hitting The Ac Line On 1993 Mustang Gt
Jims93gt
Installed new BBK long tube headers and the passenger side is hitting tight against the AC line. Has anyone had this issue and if so how did you fix it? Thanks
  • Sponsors(?)
revhead347
My mission is to out curmudgeon you
8,247
1,125
214
40
Acworth, GA
It's a known issue. It will burn up the AC line pretty quickly. The AC line has some flex to it, so it can be relocated. Go inside the strut tower and drill a hole higher up. Take a loop mount, hook it around the AC line, lift the line up a little bit so that it is away from the header, and attach it with a bolt and nut through the hole you drilled higher up in the strut tower.
Kurt
Jims93gt
Thanks I will give it a try this weekend. I didn't know if I could pull on it or if it would break.
skiwesser11
I’m currently relocating AC line for same reason... did it work out? Any leaking issues if you move it that much? Mine runs right along (touching) the header for 6-7 inches, and in way too close proximity the length of the head where the line is bent and “tucked” there by Ford.
nickyb
WAIT,you now have a pair?
5 Year Member
Apr 3, 2009
313
117
63
57
nevada
My cheapo long tubes from summit clear with no problem's, but they do leak as they are slip fit on 3 of 4 tubes on pass side ,and 1 tube on drivers.
Reactions: 90sickfox
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,372
4,400
203
42
I've installed a bunch of those cheapo headers. Get some high temp rtv next time and smear it on the tubes when assembling... they won't leak.
90sickfox
Mar 2, 2015
5,372
4,400
203
42
Just realized this thread is old... but... that method posted will work. Also, they have heat shielding in the local parts stores that has velcro along the seam. Move the line and put a heat sleeve on it. You don't have to move it alot... just up and away from the header.
wiseguyk
302
83
48
Florida
I've been wondering about how to handle this myself, though for routing away from my turbo and downpipe rather than the header itself...
Scott, do you have AC on your car? I really want to hook mine up again but have been holding off because I wasn't sure the best way to route it around the hot turbo stuff that's now in the way... :chin
90sickfox
Mar 2, 2015
5,372
4,400
203
42
I do have AC. The line by my strut tower is sleeved in heat wrap. It hasn't blown but I'm not 100% comfortable with it. Thinking about getting some fittings and aluminum tubing and bending a new section of line. I've actually been hunting at the JY to find some with the same diameter and bends that would work. No luck yet.
Reactions: wiseguyk
wiseguyk
302
83
48
Florida
Nice! Gotcha, yeah I've been toying with the idea of either getting the crimper and learning how to make my own lines, or having custom lines made and trying to run the strut tower line through the fender well.
Did you have any issues with the routing of the high pressure line from the compressor to the condenser? That one goes right by the turbo as well but seems like it could at least be finagled a bit more towards the front/cold side of the turbo.
Do you happen to know if there are any length limitations for AC lines? Like is there a point where adding too much length would negatively impact the system?
Thread starter Similar threads Forum Replies Date
fitnage Added BBK Long tube/BBK no cat X/Pypes Cat - weird sounds 1996 - 2004 SN95 Mustang -General/Talk- 17
R Exhaust set up advice. O\R H pipe or high flow cat H pipe? 2005 - 2014 Specific V6 Tech 2
96pushrod SN95 Bbk fox Long tubes sn95 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
a50ina50 Expired 79-93 Bbk Long Tubes And H-pipe Exhaust Parts 3
N Does Bbk Still Suck? SN95 4.6L Mustang Tech 3
J Bbk Long Tubes O2 Sensor Problem 2005 - 2014 Specific V6 Tech 6
A Exhaust Hello Everyone, I Need Help With My Clutch Replacement. SN95 4.6L Mustang Tech 1
Grabbin' Asphalt Bbk Long Tubes - True Bolt On Fitment?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Joe Caruso SOLD Bbk Polished Long Tube Headers Exhaust Parts 4
D Bbk Long Tube Question For Anyone Who Has Them... Fox 5.0 Mustang Tech 16
Smitty15us Expired Bbk Long Tube Headers New Never Used.... Exhaust Parts 2
Bojingles Exhaust Bbk Long Tube Headers And Catted Shorty X-pipe Tuning Problem 2010 - 2014 Specific Tech 8
Brad Compton Expired Bbk Long Tube Headers (ceramic) Fits 87-93 Exhaust Parts 2
disturbdgt bbk long tubes and vrs catted x pipe Exhaust Parts 3
WhiteCobra95 BBK Long Tube Header Install Questions 1994 - 1995 Specific Tech 15
B Brand new long tubes and BBK X Pipe Exhaust Parts 21
A BBK Long Tube headers + Magnaflow Cat-Back 15591? 2005 - 2014 S-197 Mustang -General/Talk- 1
WhiteCobra95 Where can I buy a BBK H-pipe for long tubes? 1994 - 1995 Specific Tech 4
Loco5.0 FS: 96-98 4V Cobra BBK long tube headers & offroad x-pipe Exhaust Parts 3
jeremy canter BBK CHROME LONG TUBES FOR 5.0 302 Exhaust Parts 3
D 96-04 GT BBK Long Tubes Exhaust Parts 6
jeremy canter Chrome BBK long tube headers and x-pipe Exhaust Parts 6
B BBK LONG TUBES WITH BBK X PIPE AND FLOWMASTER CAT BACK.. Exhaust Parts 3
M BBK Long Tube Headers, H-Pipe, Flowmasters and MORE NE Ohio Exhaust Parts 9
B bbk long tube headers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
callmedrlove BBK Long Tubes and H-Pipe 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
H BBK long tube headers install SN95 4.6L Mustang Tech 10
M BBK Long Tubes and Off Road H Pipe Exhaust Parts 13
X Removing transmission with BBK long tubes SN95 4.6L Mustang Tech 1
8 BBK LONG TUBES Exhaust Parts 5
EPIK Mac Long tubes, & BBK H pipe?? Will it work??? Fox 5.0 Mustang Tech 0
99FiveOh BBK Long tube headers, questions 1994 - 1995 Specific Tech 12
R bbk long tubes 1994 - 1995 Specific Tech 6
1 Anyone running a BBK X-PIPE for long tubes on your 94-95?Please help Need measurement 1994 - 1995 Specific Tech 11
GRGT1994 BBK Long tube headers hitting steering shaft 1994 - 1995 Specific Tech 5
T BBk Long tube H pipe HELP 1994 - 1995 Specific Tech 0
M BBK Long Tubes + Trick Flow High Ports? Fox 5.0 Mustang Tech 4
S matching my bbk 1 3/4" long tubes to a 3" mac prochamber??? Fox 5.0 Mustang Tech 2
S Anyone running BBK long tubes with a VRS 3" X-pipe? Fox 5.0 Mustang Tech 2
Kornnut BBK long tubes question 1994 - 1995 Specific Tech 6
Kornnut BBK o/r H piped for long tubes question 1994 - 1995 Specific Tech 1
chad9350 long tube headers: is there enough to justify Bassani for 850$ vs. BBK or MAC for.. 2005 - 2009 Specific Tech 7
mustangsquared BBK Long Tubes 2005 - 2009 Specific Tech 5
S Do BBK 1 3/4" long tubes exit parallel or offset? Fox 5.0 Mustang Tech 4
S Anyone fit a MAC Pro-Chamber to their BBK long tubes? Fox 5.0 Mustang Tech 3
C 02 gt and bbk long tubes SN95 4.6L Mustang Tech 5
YELLOW42RCODE BBK LONG TUBES 2005 - 2009 Specific Tech 22
ALMOSTFINISHED BBK Long tube clearance problems Fox 5.0 Mustang Tech 12
9 BBK long tubes collector size?? Fox 5.0 Mustang Tech 3
Team Ford BBK Long Tubes 1996 - 2004 SN95 Mustang -General/Talk- 2
