BBK SSI intake?
OOOOPS! WHAT CAM? I hear you asking and it's a hydralic ISKY.
Grind type: RR-284/294 hydraulic RPM range: 3000-7000
Valve lift int.Ex .544/.573 Valve lash: 0
Advance duration int. Ex 284 degrees / 294 degrees Lobe center: 112
.50 Duration int. Ex 238 degrees / 248 degrees
I've seen dyno tests that show the BBK running with the tubular GT-40 on a 347, and I have a friend that has one on his 306 and he loves it. But I have also heard a lot of talk AGAINST it, so I can't really say.
We put down some sad dyno numbers early on ... had several issues that day --- fuel pressure, timing and was getting oil on driver side plugs.
She runs pretty sweet, just not pulling strong enough past 4700rpm!?
This motor does develop monster torque,
