BBK Throttle Body?
Mach428
321
I was looking at a BBK throttlebody for my 88GT, the stock one is still in there and theres evidence that it needs to be replaced. I was looking at either the 65mm, 70mm, or 75mm trottle bodies. My only mods are a full exaust system and BBK cold air induction. What throttle body would everyone suggest? Does anyone know of any other mods a throttle body requires?
Depends on the intake you are wanting to run in the future. If your planning on running the stock intake, then upgrading just the TB will do no good. For one, you need to upgrade the EGR as well to match, unless your planning on getting a '93 cobra which the EGR is not required. Most stock intakes measure 57.738 mm for the opening, so pushing 65mm of air into that opening wont help, in fact it could hurt performance although such small amount you probably wont tell..More info is needed... :nice:
toss 75mm outta the mix, unless your gonna do some serious engine work. if you plan on adding a new short block, or new heads or a supercharger, go ahead with a 70mm. I went with 70mm because a friend of mine sold it to me with a Cobra Intake for 300 bucks, and they were both practically brand new. either one should be OK
Cars can run into the 12's with a stock throttle body . Bell mouth your throttle body for now.. That would be plenty sufficent. Do a nice job, take your time , and you will feel a throttle response difference. 526 CFM is the 60mm Stock T body ;the bbk 70 flows 726 CFM.!
With those Mods a 75 MM is a :nono: . If you Do Heads, Cam, Intake, Roller Rokers, and are pushing out over 300 at the rear wheels then you could go to a 70MM but really dont need to unless your going to throw a power adder on it, a 65 will be just fine unless your going to do some radical combo
Can you sing “Whistle a happy tune”? Because that’s what you will be doing with a BBK or Mac throttle body. They have an annoying tendency to whistle at idle.
The best buy is either a Ford FMS or Accufab throttle body. The FMS body comes with a new TPS sensor and IAB actuator, a highly recommended plus if you have and older car and these items haven’t been replaced. The Accufab doesn’t come with these items; you use your current ones. It is an excellent piece of machine work & the fit and finish are first class. It is also more expensive than the Ford FMS throttle body.
Size:
A 70 mm throttle body is a good choice for a stroker, pressurized induction or 351 or larger engine. Use it on a 302 if you are going to spend more time at the race track than on the street, or if you have a really hot combo that likes to rev. Use it on a stock or mildly modded engine and low end torque will suffer due to low velocity in the intake,
A 65 mm throttle body is the best choice for a stock or mildy modded 302 engine. Low end torque is good and the velocity in the intake is right where it should be.
With either size throttle body, the EGR spacer has to match the throttle body for best results. The intake manifold needs to be ported or replaced to take advantage of the increased airflow capabilities.
Larger injectors with an 88 speed density engine isn’t a workable solution. The computer won’t know what to do with them. Larger injectors would require conversion to Mass Air Flow like the 89 (or Cali 88) and later stangs. Keep in mind that speed density engines can be fussy about mods that change the airflow or vacuum. That’s why the mass air conversion is such a popular item on the performance mods list.
At Idle the engin sometimes has a tendecy to choke out due to the throttle body surface being unsmooth. I was thinking of buying a kit to clean it since trottle bodies have a special coating that does no like harsh chemicals but whats the point of were going to start with mods. We were thinking of getting a 93 Cobra intake manifold, should the 65 or 70 still match up to that? We were also planning on eventually getting 24lb injectors and a chip. I want to buy the right mods the first time and not regret it like a couple of my friends lol. Thanks everyone the previous info is very helpfull.
I have a 70 mm BBK throttle body basically BRAND NEW only used for about an hour before the guy realized it wasn't going to work with his set up (NOVA project with Fuel injection setup) I'll sell it for 110 without the EGR SPACER. This part is 190 new, if ur interested send me a message. BTW the cobra intake I AM PRETTY SURE has a 65mm opening for TB. If you do go with a cobra intake don't bother with 70mm. However I have heard other mustang owners stay away from Cobra intake, because they wanted to go bigger down the road. I'd suggest an intake with a 70mm opening so then if you wanna supercharge it down the road it will set up nicely. For the price Trick flow intakes are good, and Performer intakes are good too. But a lot of people like to go with the gt-40 which is about 100-180 dollars more than the others ones :SHRUG: Just a suggestion.
is it correct that all BBK TBs are really BBK/Edelbrock?...my friend had a 70 mm and it says both names on it...he gave me his spacer and that also says both names...are these just the older ones? or the new "power plus" ones still have this?..
on a side note: from the day he bought the car he had problems with teh TB...the springs were all messed up andmade teh pedal hard to push...but no other problems.
