Imagine...
The car is purchased, you carefully get inside, making sure you knock the dirt from your shoes before you touch the floor. Extra socks are brought to put over the pedals so they won't be scuffed. After turning the key, waiting for the fuel pump to prime, the engine is started. Easily the clutch is pressed in. The shifter is moved from neutral to first gear. Never before has a Mustang been so easily moved by letting out on the clutch with the utmost finesse. Slowly driven across the parking lot to what seems to be a waiting enclosed trailer. The Cobra sees it new home in sight, But wait... Something inside rages! Screw the trailer! The Loud pedal is hammered, 6250 RPM fuel cutoff is here! Clutch is dumped, held on to first as long as should be, 2nd is power shifted into being! Hammer down for 3rd! and 4th isn't that far behind.
The look on the sellers face would be priceless....
I would do that.
