Been having a horrible bump steer in the front end of my '99 GT
Cronus
14
Baltimore
The front end is just real sloppy. Wants to follow any sort of rut in the road. Wondering if you guys have experienced similar problems on a stock suspension. I’ve had the car aligned and still experienced the problem. She will be getting new tires here soon and another alignment/balancing. If the problem is not corrected, going to look to the after market.
Anyone ever use the Steeda bump steer kit? Any comments?
What you're experiencing doesn't sound like bump steer. It sounds like tramlining. This is typically caused by a wide front tire, improper inflation of front tire, improper toe settings, loose steering components. A bump steer kit will not help at all in this case.
I'd check to ensure that everything is tight and to spec under there. Another thing that come to mind here are worn ball joints, that could also cause that problem.
My 96 Cobra Convertible started doing exactly the same thing as soon as I replaced all 4 tires with BFG G-force T/A KDWS. I am currently experimenting with tire pressures to resolve the problem. I am thinking that the new tires have more sidewall flex than the G-force T/A KDs that were on the car until the change. Both are factory 245 45 17's.
THanks for the info guys.
Looking to buy new tires asap but I'm not sure what to go with. Been looking at the Bridgestone Potenza RE750s and the Firestone Firehawk SZ50 EPs
Looking for a daily driven tire that will hook in a straight line atleast a little. Have any suggestions?
I can tell you what NOT to buy!!! I had none of these problems with my old tires so I would recommend staying away from the BFG G-force T/A KDWS, at least until I can get my favorite front end guy to take a look at the car. I'll pa$$ on anything of value from that vi$it.
ok i have the exact same problem... new tires and wheels...
the wheels are 9 inch on the fronts, wider than the stocks, and the tires are Kumho Ecsta 245... would that be the tramlining?
Took the Cobra to the alignment guru yesterday. Told him how the car was following the ruts in the road with the new tires. His first response was that it sounded like excessive toe-in (one of the possibilities mentioned in the Tirerack article). He put the car on the alignment rack and sure enough, it had about twice the specificed amount of toe-in. He made the correction and it made a big difference. He had checked the alignment about two months ago for me and it was fine, and I have been careful not to hit anything, so I was surprised that it needed adjustment. He told me something that I didn't think about but can understand to some degree--the new tires could mean a different overall footprint.
So, lesson learned # 1: In the future, new tires = new alignment, no matter how recent the last one was performed.
Before driving the car this morning I adjusted the tire pressures downward (also recommended in the Tirerack article) to 34 psi F, 31 psi R, from the 37 psi F and 34 psi R I had been running. I'd been experimenting with the higher pressures to try to remedy the problem. The difference with the new tire pressures and alignment is like night and day. There is still a hint of tramlining on really bad road surfaces, but otherwise it is gone, to the point that I don't think I'd even notice it at all now if I hadn't been through this and weren't really looking for it. Another benefit is that the car no longer rides like a lumber truck!
One other thing that my alignment guy told me worthy of passing on: some car and tire combinations, for whatever reason, just don't work well together. Lesson learned #2: Buy your tires from a place that offers a 30-day ride replacement guarentee, especially if changing brands, sizes or models. I bought these BFG's on sale at a military exchange. If I hadn't been able to get them straigtened out I would have had to live with them as they have no ride guarentee, and these were the only tire they carry in my size.
I would now conditionally recommend these tires (condition being that you can swap them out for something else if they don't work on your car). Nice thing about these are that they have a treadwear rating of 400, are all-season and are relatively inexpensive. They are also much quieter than the G-force T/A KDs that had previously been on the car, and are a non-directional tire. I paid $125 apiece for them.
The last thing that you may want to look at is the condition of your front tires. In your original posting you said that you had aligned your car. Somewhere I read of a case where someone was having this problem and it was as a result of a badly worn front tire. Might be worth doing a rotation as a short-term fix if you haven't tried that yet.
Thanks a lot for your input Marine, I'm thinking that I may be experiencing a similar toe problem. I'm going to be buying new tires this weekend and having everything done. Lets hope my issue is resolved…
Well guys I decided to buy the tires last night and went with the Potenzas. Talked to the guy for a while before he took the car to explain the problem and make sure he was somewhat competent. Even though it has been pretty bad weather here (ice/rain) I can tell you the tires and alignment have made a big improvement. I am still having a little problem in one area of the highway but that is the roads fault, not the cars.
Now to figure out what to do with all the money I am getting back from the IRS…. :)
Thanks again for all your imput
