Any one had a beeping noise coming from their dash that sounded like the emergency broadcast warning, or almost like a battery back up losing power? This started this morning and almost can make it crackle by moving the car??
Thanks
Thanks
OK so I guess I will pull the radio out and hear if it's it. Then unplug!
5 beeps doesn't indicate the code it means the indicator is out and a fault code is present. remove the radio and mounted under the heater controls will be a blue box with 3 8mm bolts, unplug it and remove at your own discretion. If you have a working air bag light and pull the box the light will blink non stop so the bulb will also have to be removed. Be advised you will no longer have a working air bag system and you do so at your own peril. just covering my butt.
That sounds right. I thought the 5 beeps was a code because my air bag light had been flashing 5 times in a row. Then when I took the light bulb out it dinged 5 times.
I agree with everything you stated, not tryn to disagree at all.
