Bell Housing Stuck!
  • Thread starter Thread starter 92GreenGT
  • Start date Start date Apr 9, 2004
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Apr 9, 2004
  • Apr 9, 2004
OK, I have yet another question. In the middle of my clutch install. The tranny is out and all of the bell housing bolts are out. It is stuck on the two dowels or something. Thats the only thing left that could be possibly holding it in. Am I missing something somewhere or what? Laying on the ground for this type of work doesnt give you a lot of room to swing a hammer I have pulled and hit as much as I can and its not comming. Any tips or ideas?
Dave
Schlodes
354
Lidsville.... West side dawg..
Apr 9, 2004
  • Apr 9, 2004
If you have all the bolts out and trans out etc,... its likely stuck on the dowels [dowels rusted a little and alum on the housing corroded.. ]. What I do is take a small straight screw driver, and with a hammer lightly tap the end of the screwdrver in between the bell housing and the engine block. Dont go nuts pounding it all the way in. Once you have gotten it to move a little go over to the other side and do the same, do this in a few spots and it should reach a point where you can muscle it off. Good place to start with the screwdriver/hammer would be close to the dowels as possible.
M
Matts89LX5.0
1,314
Long Island, NY
Apr 9, 2004
  • Apr 9, 2004
wedge a screwdriver in a lightly tap it in on each side until it comes off. Pretty much what Schlodes said ^^
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Apr 9, 2004
  • Apr 9, 2004
Ok, while you all posted it came out. Just stuck like you all said. Thanks for the help.
Dave
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
TKX Install in the Coupe
  • AeroCoupe
  • Apr 12, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine Cant get harmonic balancer puller to work… crank just spins
  • AnthonyA1234
  • Aug 26, 2023
8K
Fox 5.0 Mustang Tech Aug 27, 2023
AnthonyA1234
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
