Bellhousing, RAD 4-speed to 305 Help.
  • Thread starter Thread starter whisenand
  • Start date Start date Apr 9, 2008
W
whisenand
9
  • Apr 9, 2008
I want to use my original 4-speed out of my 75 coupe.Does anyone know which bellhousings will mate it to a V-8?
mean78
89
  • Apr 9, 2008
so you want to meet it with a chevy 305?........or did you mean 302/306?
if a 305 i have no clue. but if you have a 302, you just need to find a RAD 4 bell housing.
kcobra302
864
latham ny
Apr 9, 2008
  • Apr 9, 2008
all 260, 289, 302, 351 based small blocks will accept the stock bell from a v-8 4-speed mustang II. keep in mind the v-8 4-speed bell is specific to mustang II.
there may be others that can be massaged but i am not aware of one. the t-5 bell would be an option only if you were going to a 5 speed.
someone can chime in to confirm but i believe the v-6 4-speed bell has a different bolt pattern.
W
whisenand
9
  • Apr 9, 2008
Sorry, I meant 302. Any way to identify the correct bellhousing with a part number?
$50COBRAII
60
  • Apr 9, 2008
Do you have a v-8 rad transmission? I'm guessing since you said its out of a 75 that it is not. In any case the v-8 and 4/6 transmissions used a different input shaft and different gear ratios. The ratios would not stop you from using but the input shaft will.
W
whisenand
9
  • Apr 10, 2008
I did not know the shaft was different. Thanks for the info, I guess it is back to the drawing board.
mean78
89
  • Apr 10, 2008
you can never go bad with a t-5!....i will be doing my conversion as soon as its warm!
WOOT!
W
whisenand
9
  • Apr 10, 2008
Will I need to shorten my driveshaft if I go T-5?
Dano78
2,633
Vancouver, WA
Apr 19, 2008
  • Apr 19, 2008
Yes, most likely. But that depends on you current dirvetrain that is in the car now.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
