I'm doing a T5 conversion on a 68 and things aren't looking right for the clutch fork position. With the trans out, the clutch fork is 3/4 of the way forward before the T/O bearing touches the pressure plate. I'm using used parts and wondering if I have a 94/5 bellhousing when I should have a 93 /earlier bellhousing. I know the 94's are set back further. The pivot stud is not adjustable.
Does anyon have a part# for the 94/5 bellhousing or a dimension (block to trans mounting surface)? Actually, I could use the 93/early dimension or part# too.
