Ok I didn't want to intrude on another thread, but it got me thinking.
Am I correct in saying 351 (C and W) and 302 blocks will use the same bellhousing?
What is a 6-bolt block, and what is the alternative to a 6-bolt?
Why are 78 - 93 302/351 different to 5.0L (1994 - 95) scattersheilds and different to 65 - 78 302/351? Is it ONLY because of the type of clutch actuation and transmission input shaft length?
Are 78 - 93 and 94 - 95 bellhousings made for long input shaft transmissions? Why are they different from each other?
If I buy a new 302 block, will a bellhousing or scattershield that will fit it be interchangeable onto a 351? Will it be a 6-bolt block? (I ask this because it seems to be the superior design, as it is mentioned specifically when looking at scattershields.)
Onto flywheels
Am I correct in saying any size flywheel will fit into any of these bellhousings? (As long as it is the right imbalance for the crank.)
Cheers!
Onto flywheels
Cheers!
Correct me if I am wrong but don't scattersheilds vary by the type of transmissions?
) You can find these bolted to the heads of 70's 302's and 351's. It's a cast aluminum or iron piece that's bolted to the head with 2 bolts and has 2 other threaded holes cast into it. Sorry, don't have a pic of one.
