Belt Question...
  • Thread starter Thread starter AnthonyR23
  • Start date Start date Jun 4, 2007
AnthonyR23
661
Ontario
Jun 4, 2007
  • Jun 4, 2007
Hi... I got under drive pulleys awhile ago... but later on found I was having charging problems.. even with the 3g alt... so I bought a overdrive alt. pulley... I also deleted the a/c.. when I did this I got a new belt.. (stock size of mustang without ac) but I think it is a bit to long... since I put the smaller overdrive pulley on... any ideas about what size belt I should get.... anyone know what size the stock belt is without a/c.
Thanks
jtfairlane
468
  • Jun 4, 2007
Use a piece of string and wrap it around all the pulleys that you are running and use the string to measure as close as you can the new belt length you need. Use that number to buy a 6 rib serpentine belt in your new length. Most serpentine belts' part numbers last couple digits indicate the length.
whtpny
338
Spokane WA.
Jun 4, 2007
  • Jun 4, 2007
You should be able to call the company the pulleys came from and get an answer. I just do not see how to get a good measurement without moving the adjuster to the right place. But what do I know, I have no pullies and I still have AC.
jtfairlane
468
  • Jun 4, 2007
What good would that do him? The pulley manufacturer would only have the belt part # for a stock application. He has a/c delete and is using a different alternator pulley which would make their belt part # useless.
AnthonyR23
661
Ontario
Jun 4, 2007
  • Jun 4, 2007
I guess I could just take the belt off.. bring it to canadian tire... and get one slightly shorter... kinda a pain...
jtfairlane
468
  • Jun 4, 2007
AnthonyR23 said:
kinda a pain...
Welcome to hot rodding cars...
BaXTeR3221
917
Orange County, NY
Jun 4, 2007
  • Jun 4, 2007
+1 for that method. I'd buy a couple belts close to the size and then just return the ones that don't fit. It's an annoyance, but it's probably the easiest way.
whtpny
338
Spokane WA.
Jun 5, 2007
  • Jun 5, 2007
The companies that make the pullise obviously know which belt to use. That seems much more efficient than trying to measure around the pulliues and buying a few belts to get it right. How do you compensate for the tensioner. That is what seems to be the variable.
jtfairlane
468
  • Jun 5, 2007
You don't seem to understand, so let try repeating myself.
The pulleys manufacturer will have an accurate belt part #, but ONLY for a stock application with all factory accessories. Now, since he has an OD alternator pulley, which is a different size than the alternator pulley they included in their kit....AND he has deleted his A/C, the belt part # they have for his kit will be totally wrong for his setup.
So NO, getting a belt part # from the pulleys manufacturer will do him no good.
bloopbloob
578
Alberta
Jun 5, 2007
#10
  • Jun 5, 2007
  • #10
if they are aluminum pullies, be warned after a few minutes of idling/driving, the belt will get aluminum all over it, and you won't be able to return it.... (yeah, learned the hard way, 3 extra belts $20-45 each!!!) if the pulley is smaller, just get a belt 1'' shorter than what u have now and try it out! seems pretty straight forward to me!!
AnthonyR23
661
Ontario
Jun 5, 2007
#11
  • Jun 5, 2007
  • #11
sounds good... another quick question... there such thing as a underdrive smog pump pulley... if there was one.. then that would offset my overdrive alt pulley.. and then I could just keep this brand new belt I just bought...
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
