Belt Question...
AnthonyR23
661
Ontario
Hi... I got under drive pulleys awhile ago... but later on found I was having charging problems.. even with the 3g alt... so I bought a overdrive alt. pulley... I also deleted the a/c.. when I did this I got a new belt.. (stock size of mustang without ac) but I think it is a bit to long... since I put the smaller overdrive pulley on... any ideas about what size belt I should get.... anyone know what size the stock belt is without a/c.
Thanks
Use a piece of string and wrap it around all the pulleys that you are running and use the string to measure as close as you can the new belt length you need. Use that number to buy a 6 rib serpentine belt in your new length. Most serpentine belts' part numbers last couple digits indicate the length.
You should be able to call the company the pulleys came from and get an answer. I just do not see how to get a good measurement without moving the adjuster to the right place. But what do I know, I have no pullies and I still have AC.
What good would that do him? The pulley manufacturer would only have the belt part # for a stock application. He has a/c delete and is using a different alternator pulley which would make their belt part # useless.
+1 for that method. I'd buy a couple belts close to the size and then just return the ones that don't fit. It's an annoyance, but it's probably the easiest way.
The companies that make the pullise obviously know which belt to use. That seems much more efficient than trying to measure around the pulliues and buying a few belts to get it right. How do you compensate for the tensioner. That is what seems to be the variable.
You don't seem to understand, so let try repeating myself.
The pulleys manufacturer will have an accurate belt part #, but ONLY for a stock application with all factory accessories. Now, since he has an OD alternator pulley, which is a different size than the alternator pulley they included in their kit....AND he has deleted his A/C, the belt part # they have for his kit will be totally wrong for his setup.
So NO, getting a belt part # from the pulleys manufacturer will do him no good.
if they are aluminum pullies, be warned after a few minutes of idling/driving, the belt will get aluminum all over it, and you won't be able to return it.... (yeah, learned the hard way, 3 extra belts $20-45 each!!!) if the pulley is smaller, just get a belt 1'' shorter than what u have now and try it out! seems pretty straight forward to me!!
sounds good... another quick question... there such thing as a underdrive smog pump pulley... if there was one.. then that would offset my overdrive alt pulley.. and then I could just keep this brand new belt I just bought...
