Whats up guys. Im goin to the track this weekend and I want to get a belt that deletes the power sterring. The A/c and the smog pump are already out so I just need the belt size to fit the Crank, Water Pump And alternator. Thanks a lot guys
43 inch belt. I run it all the time. Alt, ten, water pump, crank. But you will have to let the rib side of the belt run on the water pump. Do you have underdrives? If so it maybe different size. I am running under drive alt and crank. The best thing to do is take a pieace of string and run it around everthing and measure it, should be right round 43 inch or so depending on pulley sizes.
