bent push rod
873Stang
221
riverside
what would cause a push rod to bend? i was doing 80 on the highway and yea
what brand push rod is good comp cams???
and do the valve need to be adj with a filler gauge or how do you know how many shims you need ?? thx
a push rod will bend if you have push rod guide plates and are not running hardend push rods. All of the after market heads Ive seen come with the guide plates. So there is a possibility this is your problem. when you replace them make sure the ones you are buying are hardend. Chris
