Bent pushrods in 351w
just picked up a new stang last nite with what the guy said was a blown up 358w motor got the valve covers off today and 2 push rods on the driver side head are bent into a U shape and the rocker arms are sitting on there wedged in crooked... how does this happen? do i have to take the whole engine apart to make sure of any other damage? or can i replace these 2 pushrods and rockers?
odds are the cam shaft lobes will show damage aswell. You are probably going to have to remove it and check. Also it may be worth your while to inspect cam bearings aswell. As for how it happens? maybe the guy over revved engine and valve springs haddent shut before push rods were coming up again. maybe incorrect installation of rockers?
i would go ahead and just replace the pushrods, rockers and lifters....what do you have to lose? When you are replacing the lifters look down in the bores for any visable damage to the cam journals
