bent special K
will_95gt
298
Austin, TX
my front right tire is like three inches farther back then my front left... lol
after further investigation i've realized my k member is bent. anybody know how much a new one runs and how difficult a self-install would be? Would i have to get it re-aligned?
The isn't too bad, but it is time consuming. Count on spending at least a full day on it. Basically you have to remove the entire front suspension, remove the motor mount to k member bolts, raise the engine up a couple inches and support it there, then remove the 8 bolts holding the k member to the frame. You will need to align the new k member with the frame before bolting it back in place.
Here's the instructions I used when I swapped mine. http://www.maximummotorsports.com/c...r2.pdf?zenid=5c3b050d37f0a559a7572cc8391d5673
it is very time consuming, plan on an all day event if you know what you are doing. some of them dont fit very well and need the holes to be reamed to install the bolts. not good on a brand new part!! :mad:
yes, alignment is needed, as you drop your suspension for the install. anytime you remove suspension compinents, you should get an alignment.
I run a PA racing K member and was extremely happy with its fit and finish. It also offers some of the largest header clearance of any K member out there due to the way it bolts to the frame.
Yeah it does! I was just putting my stock H and headers back on for smog and wow im glad i bought that thing. It made the install a breeze.
