Best Cast Iron Heads
They're pretty comparable. The AFRs are CNC ported and will slightly outperform out of box TFS cast 170s. The 170s have a ton of potential, though.
The ARP washers are wide enough to hold them down. The dowel holds the head in place, not the bolt. 10 years ago, no one even knew what step washers were. It's something someone invented for a problem that didn't exist to make money.
Kurt
You don't even need the step washers. Just bolt them on.
Kurt
I could not disagree more. I have seen several cars with blown headgaskets when no step washers were used. I highly doubt that this expense will break the bank..
I actually looked them up. They advertise that they are for keeping the aluminium from collapsing into the bolt hole. It's just never a problem I've had before. I don't see how they could have any effect on the head gasket.
Kurt
I think a lot of it has to do with the heads moving around on the deck surface while the engine is running. I think that this is exaggerated as the hp levels and cylinder pressure increase. I would compare this to using smaller bolts in your rear control arm mounts. Sure they may have enough clamping force to tighten to the desired spec but there are more than just linear forces applied to these bolts and I believe that this will result in a failure. I know that the cylinder heads have locating dowels, but they are located on two opposing ends of the cylinder heads. In both cases where I have seen blown head gaskets using no step washers, the gaskets have been pushed out from one of the two center cylinders.
Reactions: krazedstang
No. Nic has TFS TW CNC ported 205s on his 302. He has some super impressive results with them too, but that's an expensive head, and the AFRs are not even cheap.
Anyway, if you're concerned about notching, consider the TFS heads with their "twisted wedge" approach, they can be run with most cams without PTV clearance issues.
To me, the milling question comes down to whether or not you want to shave the heads to gain some compression. If you don't mind running premium, don't have blower or turbo ambitions, and are trying to get the most out of your combo without finding another way to boost compression, then mill 'em. Just leave yourself a little room to flatten them again later before you sell them or reuse them.
Correctomundo... You can run the TW 170's with the 2.02/1.60 valves on a stock piston as long as the cam lift is under .540 If memory serves me right. BUT.. I would always check the PTV clearance regardless. Cheap insurance.
Just know if you mill the heads it may cause alignment issues with the intake holes and change the pushrod length. Plus it even more of a reason to check PTV clearance.
FWIW, peak lift has absolutely nothing to do with valve clearance. My setup has .570ish lift and I have plenty of clearance, on true flattop '86 pistons. It's all about where your valves are when the piston is hanging around TDC (exhaust closing/intake opening).
Reactions: TOOLOW91
Well I wouldn't say it has nothing to do with it.
Kurt
From an interference 351w. For what its worth, lol. This is what happens when your friends don't listen to you when you say checking PTV is a must!
Isn't the 5.0 a non-interference motor? Maybe the rule of thumb is that .540" lift is what makes it an interference engine? Just curious...
I actually don't know if the 5.0 is non-interference in stock form. I've heard people talk about it before, but I've never seen anyone verify it. It's moot though, because we're talking about aftermarket heads and cam, and heads that put the valves in non-stock locations to boot.
Kurt
Yep, sticking to my guns on this one. Peak lift happens on the far side of 90 degrees ATDC (for the intake) or BTDC (exhaust)- when the piston is more than halfway down the bore. In a 302, that's more than 1.5" deep in the block. So, for the typical sub-.600" lift cam, you've probably got more than an inch of clearance when peak lift happens.
Pic for reference.
Reactions: TOOLOW91
I have 1.6 frpp pedestal rockers, I'd be back in AFR price range if I bought stud rollers. How much can the AFR's be milled?? I like the high compression n/a. Should I do 165cc or 185cc milled?? I know I would have to notch for the pistons on the 185cc though.
