Best connecting rods??
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
ive been looking into a rebuild using the stock 302 block and crank. I think im going to go with the Forged TRW .030 pistons. What are the best Rods?? Should i go forged with them as well??? All opinions welcome!
I bought the Eagle "SIR I-Beam" rods. good for up to 500hp in a small block, and they are bushed for $285.95. i guess it depends on how you are rebuilding ecaxtly. if you are wanting a giant blower or a ton of nitrous, you might just want to go with H beam rods. Mine is N/A and my machine shop said i would be fine with the I Beams.
Most rods are forged anyway due to them having to endure the highest level of stress in an engine - which leads me to the point, don't buy junk in this department.
Eagle are hard to beat, Manley is another good manufactuer of good quality.
I went with the same rods when I built my engine.
I'll go ahead and lay the slap in your face with this site I lucked out on with:
http://www.cnc-motorsports.com/category.asp?CtgID=3182
Even better was I got them $21 less than the advertisement now when I bought them :)
I really doubt a rod will go before the block will. The time the rods recieve the most stress is when its going over tdc and the rod literally wants to stretch....putting a blower or turbo on the motor could actually increase a rods strength. Instead of using the crank to draw it down, the boost will be of a slight aid.....Using a stock block build i would just do stock rods with ARP connecting hardware....
I would not use TRW pistons. Either SRP, Ross, CP, or Probe pistons. stick with major brands.
Eagle and Scat r the leaders in offshore 4340 crank and 4340 rods, quality stuff good to 1000fwhp. With ARP 2000 rod bolt upgrade good to 1200fwhp. Stick with the majors.
Dude, TRW is a very major brand. The factory forged pistons in our cars are made by TRW, and most performance aftermarket pistons (the ones under 600 bucks a set) are made from TRW blanks. Yes they are not quiet as nice as the high end JE's or Ross's, but they are a good bang for the buck, by the way the easiest way to get TRW's these days is just get the Speed pros.
If TRW isn't MAJOR, I dunno what is. They make a LOT of OEM pistons.
HAHA, for sure. That about as big as you can get. As to the person with the Hawks racing rods, they did seem to be good quality? i was planning on thier I beams for my stock block 331 build. I figured since its all forged and i have to get it balanced whats the difference right?
I re-used the stockers in my motor, i just had em resized and used ARP hardware. I also went with JE's SRP pistons, and the quality was very impressive. The guy that balanced my rotating assembly said they were very consistent and the motor runs very very smooth. No real need for aftermarket rods in a stock block motor. I've heard the stock rods will handle just about 450 hp, which is all the block is safely good for. good luck
