Best Frame Connectors?
I have a 67 coupe with a 393 that is going to see some street/strip use and my car only came with one torque box. So I need to install some frame connectors. I would like to weld them in. What brand would you recommend?
Even if you get connectors, you should still ad the RH torque box.
Even better than add-on connectors is to install convertible inner rockers. Much more effective than connectors, because that's what they are, only like 4 times as strong as add-ons. Not an easy project, though, and of course there's no going back.
The thing I don't like about all the connector on the market is that they don't attach to any structural metal in front. Every thing I have seen attaches to the floor support, which is thin metal. The front frame rail is much more substantial. The frame rail ends about a foot in front of where most connector start. Mine go into the front frame rails up to where the rail angle up. Mine are about 20" longer than what you can buy and are through the floor. They are a pain to put in, but tie th frames together good.
Attached below. Surprise they have not been mentioned by anyone already. Once in they look like they are part of the car and not and add on. They dont attached to floor but hug it nicely. Basically cut open end of front frame rail and slide in and weld. Back end fits up to rear frame rail and welds in. Pretty easy to put on - I did them in a couple hours with my mig. I've heard other that use muffler shops to weld once they prepped frame rails.,
1965 - 1973 Mustang Subframe Connectors & Drive Shaft Loop
The connector fits pretty tighlty within the frame rail. Slides in about 10". Besides welding around the opening, you drill a couple holes in frame rail first. One connector inserted into rail you plug weld those also Pretty solid fit.
