Best less than $1000 Perf Mod (NO SPRAY)!
4.10s, chip (gotta do this on an auto, it's not just a speedo thing!), and catback would likely put you just over a grand, depending on labor. Get welded in mufflers if you must stay at a grand or less...
Since you have an automatic, you need to get a transmission cooler first and foremost if you dont already have one. Heat is the number 1 killer of the automatic transmission. A shift kit and gears would also be a good idea. I'de do a torque converter as well but they're sort of expensive.
Here is what the automatic needs:
Transmission cooler
Jerry mod shift kit or performance valve body
Torque converter -no less than 2800rpm stall
Gears - if n/a no less than 4.10's.
Sport chip - you will need one of these to correct your shift points and speedometer with a gear change.
Im not going to say much about the 0-60mph, I dont think to much in those kind of terms lol. If I had to make a guess Id go with .2-.3 tops off your 0-60.
In terms of quarter a pretty much stock 99+GT can do it in what 13.8-14.0s with a good driver. Take the same driver and conditions and you could probably shave .3 to possibly .4 off once you learn to drive really well with them.
I used the G-Tech performance meter. Several reviews described this device as extremely accurate. It not only lists 0-60 mph time, but 60 ft, 1/8 mile, and 1/4 mile times.
GinoGT said:
:rolleyes:
One ounce of wheelspin and the accuracy goes down the drain. Weight needs to be exact as well, or else the same happens.
Take it to the track.
there are calculators online that will calculate your 0-60 time from your 1/8 e.t. and mph from acceleration at the track...
so in reply to the 0-60 people, bring you car to the track and then put yer stuff in the calcs and you will figure out the differences there.
