mkk50 said:
Ok, i have a C&L 73mm maf calibrated for 19#ers, and at light throttle above 2k the engine pings, and when using the stock maf and changing nothing else, it doesnt ping. Is there any other aftermarket maf out there that wont cause this? im in no rush but im planning to buy the tfs kit soon and dont want these problems when i switch to 24#ers.
Well, when you change to 24's, you will be changing the MAF/MAS in some way to match the larger injectors.
It may be that the problem just goes away when you convert to 24Lb injectors and the corresponding MAF.
Or, maybe the ping gets worse.
No real way to know at this point.
Things like this are why folks say that C&L meters are crap.
The real frustrating part is that the meter may work perfectly with the 24Lb injectors
If you want to fix the problem now (while running 19Lb injectors), then pick up a MAF/MAS from a 94-95 Mustang. This stock MAF should be more accurate than the C&L.
stock is better than Aftermarket?
Did I say that?
Look for a 70mm Tube with a F2VF sensor.
The down side is that the sn95 MAF/MAS can't be used with 24Lb injectors (not with out a custom tune anyway).
I guess what I am saying is...
Fixing the MAF now, doesn't do any good for when you convert to 24Lb injectors, as you will have to modify the MAF at that time as well.
Not sure if that helped, or just added to the confusion
jason
