VT Stage 2 cams, Steeda pullies, Fox Lake heads, new upper intake, P&P'd Accufab plenum/TB, bigger MAF, bigger injectors, reputable CAI, electric water pump, since you'll be needing a tune, have it cal'd for the gears/cams/heads, and advance the timing, etc.
I hesitate to guess on what you'd be at.. there are guys with the major boltons, stage 1 cams, minus the heads pushing 300rwhp easy.
However, to answer your question, N/A mods don't compare hp per dollar to a supercharger or turbo. You're looking at 1200 for a good intake, 600ish for the cams, 1400 for the heads, several hundred for the pump, injectors, maf, etc.. 400ish for the tb/plenum, 180 for the pullies, few hundred for the tune,etc. For $4800 you can slap a 9# intercooled KB on and smoke every bolt on gt on the road.
