Best Pistons For A Supercharged Motor?
Huh?
Any piston will work with a supercharger,but one with lower static compression ratio's (9.5-8.0:1) will work the best.Forged pistons are stronger than cast/hyperutectic and you should run them to get more reliablity out of the motor on boost.
Personaly,I like JE
Im also running JE's SRP pistons....and i was very impressed with the product. I would suggest spending the money up front because tearing a motor down to replace cheap pistons will really piss you off. I would say stick with a lower comp. piston around 8.5:1. good luck man
