best placement for o2 sensors?
foghorn67
I'll save you the time and choke myself
1,532
Orange County, CA
I just picked up a couple of oxygen sensors for my stang. one for each cylinder bank. It will be hooked up to an autometer air/fuel ratio gauge, and wired with a switch to select between the two.
Where is the best place for the shop to weld in the sockets. immediatly after the primary joins together? near the header collector/pipe (end of the header)?
or does it matter?
thanks
Oh my, I read an article on this in one of the magazines. I think I remember it saying to install the sensor in the collector(geez, getting old sucks). I gave my friend a copy of it as he was adding the sensor to his supercharged Porsche. On a side note, my GF's Honda has two sensors, one in the front and one in the back, why, I don't know.
Copy cat! Next you're gonna tell me it's a Phantom gauge! ;)
You want to put them as close to (or into) the collector as possible. I didn't want to put them in the collector, so I mounted them in the pipe connecting to the headers, real close to the collector. Placement is especially important if you are using a 1 wire O2 sensor. The 1 wires use exhaust temp to heat the element. If the O2 doesn't get enough heat it will not read correctly. The 3 wire O2 sensors are less critical because they use a 12v source to heat them.
I ran the sender wire from each sensor to an on-off-on toggle switch so I could switch from bank to bank, or turn the dancing lights off all together.
before the cat, and after the cat.
dont know about all honda's. but the obd2 civics had the cat cast into the exhaust manifold.
