GreatWhite Member Feb 24, 2006 232 1 17 Fairfield, PA May 14, 2006 #1 May 14, 2006 #1 What do you guys suggest? I was thinking water temp and oil pressure, but what about a third? Just lookin for opinions...
Bad92GT The 5 Minute Plan Man Jun 10, 2004 492 0 0 SC May 14, 2006 #2 May 14, 2006 #2 temp/oil psi/ and it depends.. if you run boost then of course a boost gauge.. theres also fuel pressure gauge.. they make just blank gauges to fill in the hole until ya need a gauge for somethin else
Skoobie Damn...Tyler65's hot! May 25, 2003 655 0 17 Vancouver, WA May 14, 2006 #3 May 14, 2006 #3 I would guess a Tach? Ive got a two pod pillar with Temp and Oil, my next choice would be a tach.
Aaron 20+ Year Stangneter Dec 5, 2003 94 35 38 Buffalo, NY May 14, 2006 #4 May 14, 2006 #4 voltmeter gets my vote if your car is stock...
Ozz I think I have a problem here. Founding Member Jul 27, 2001 3,514 66 109 Canton, MI May 14, 2006 #6 May 14, 2006 #6 My first two were temp & volts (got a system, had to monitor), then boost & A/F came 'round Oil pressure and FP are popular ones, too.
bluevenom867 I will have images of molesting stuffed animals in Dec 15, 2003 1,704 1 0 St.Petersburg,FL May 14, 2006 #7 May 14, 2006 #7 Oil/Water/Volts If you dont got a tach already,get on after thous then.
GreatWhite Member Feb 24, 2006 232 1 17 Fairfield, PA May 14, 2006 #8 May 14, 2006 #8 yeah i will probably go with the volt to go along with oil psi/water temp... i wanna mount some in my center vent, but still want some air flow... i think i'll do volts, and water temp in there... then i want a tach pod w/ the two other guages, prolly go with oil pressure, and possibly boost when i get my vortech?
GreatWhite Member Feb 24, 2006 232 1 17 Fairfield, PA May 14, 2006 #9 May 14, 2006 #9 i've also heard of oil temp guages being something good to invest in... what about one of those?
Ozz I think I have a problem here. Founding Member Jul 27, 2001 3,514 66 109 Canton, MI May 14, 2006 #10 May 14, 2006 #10 That'd probably depend on what your setup was and the likeliness of you having to worry about it
