Route666 Active Member Aug 16, 2003 1,652 6 39 Brisbane, Australia May 19, 2004 #1 May 19, 2004 #1 As the title says, what are the options, and what are the best traction aids for leafs?
65fastback2+2 New Member Aug 4, 2003 1,229 0 0 Louisville, KY May 19, 2004 #2 May 19, 2004 #2 i have drag traction bars on mine which im told need to be removed because they dont work properly.
MustangMatt1966 New Member Mar 11, 2004 1,004 1 0 Orlando Fl. May 19, 2004 #3 May 19, 2004 #3 you can go with your choice of traction bar...usually braces around the the leaf spring and then welds to the underside of the car. Or you can go with the cheaper version by lakewood=slapper bars.
65fastback2+2 New Member Aug 4, 2003 1,229 0 0 Louisville, KY May 19, 2004 #4 May 19, 2004 #4 i have heard the term cal-tracs alot on here
R Ronstang New Member Apr 4, 2004 1,294 0 0 Houston Texas May 19, 2004 #5 May 19, 2004 #5 CalTracs......they are the best if serious traction is your need. http://www.calvertracing.com/info/info.htm
2bav8 Founding Member Nov 30, 1998 2,511 1 47 Mesa, AZ May 20, 2004 #6 May 20, 2004 #6 After upgrading from Shelby underriders to Cal-Tracs, I can definitely say that the Cal-Tracs are far more effective.
allcarfan The Answer Man Founding Member Apr 8, 2001 2,458 1 56 North Atlanta May 20, 2004 #7 May 20, 2004 #7 I have clatracs installed....havnet had a chance to try them babies out yet though!
Route666 Active Member Aug 16, 2003 1,652 6 39 Brisbane, Australia May 20, 2004 #8 May 20, 2004 #8 Thanks all, sounds like Caltracs are loved by all.
