Best Way to Remove and Install Pilot Bearing?
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
The old one is really stuck in there. What is the best way to get the old pilot bearing out of the crankshaft and then install the new one without damaging anything?
I recently had this same problem. I tried the grease trick but it didn't work. Go to auto zone and rent a "blind hole puller" . It was 140 dollars to rent (you do get your money back). Worked like a champ.
I've never had the grease work for me, and the only pullers I tried were cheap ones that bent. I always end up cutting the old one out with a chisel (carefully). It works well, and if you are careful you won't even nick the crank. I did the clutch in my brother and laws explorer. The pilot bearing was in the flywheel. NICE! You just tap it out with a hammer, it was sweet. I wish the 5.0s were like that.
Mine was a royal pain in the ass... I rented a slide hammer for the job, but that sucked. In the end, the grease worked for me. The trick is finding a dowel that is the right size, to just barily slip through the pilot bearing (old input shaft maybe).
To tap the new one in, i used an impact socket + hammer and it went in straight as an arrow.
When everyone talks about a dowel, do you mean something like a carriage bolt the same diameter as the transmission input shaft?
I've done it three ways, grease, grinder and puller. Try the grease first then puller then mangle it if no luck. If you choose #3, be very, very careful that you do not harm the crank.
Well it's out thank God. I went to Sears and got the Craftsman 1/4" steel chiesel. Then spent 2 evenings under the car slowly picking the old one apart. Crankshaft has some minor nicks in the bearing pocket that should clean up with emery paper. Is the new bearing normally tapped in dry or lightly lubricated?
