FastA$$89Vert said:I got one of those summit rear kits with the cover bolts etc.
They give you these long bolts with a flat pedastal on the end, does the pedastal go into the rear against those caps?
FastA$$89Vert said:Directions said make sure they dont touch at all.......
Of course I run into another problem, one of the original bolt heads broke off, now i have to find a way to get the bolt out of the rear completely flush with where the cover would be........
any ideas
HISSIN50 said:Are the girdles really that thin of a metal? I considered getting one, and one reason was for a little stronger metal (to help with cover flex and the small drip that can result).
Yeah, that is what I expected (the girdle being stout). Thin gauge metal would not have the integrity to support the bearings caps.Shakerhood said:I did not think my Aluminum Girdle was thin at all, the stock cover is thin!
