Best year/type of mustang for drags
In my opinion, 89 - 93 notchbacks would be best suited because they weigh a lot less than hatchbacks. But, you see every style and year racing with sucess. Ultimately it comes down to money and proper part selection.
Generally speaking the notch stangs are the perfered weapon of choice.
They are the lightest and the strongest. But as mentioned you can get the same performance out of any style just depends on how well you engineer it and how much you sink into it.
For a straight up drag car I'd go with a four eyed notch. They are all ready carbed (except for 86) and usally lighter than the newer models. A four eyed notch would be the best choice all around.
black92gt said:
I think I would go for a early 80's notch, 4 cyl or 6 cyl, and manual everything.
Yup, they practically give those cars away. Especially since a pure drag car you should build a healty rear end, trans and motor. Then gut the car. That is why they would be best. However the 85 and newer have the stronger 8.8" rear. Unless you want to get nasty and go with a 9" it won't matter then.
If you are going budget an 85 is the first year of roller cam, last year of carb and has the 8.8".
I guess it all depends on fast you wanna go. What ETs are you looking for?
if you can get a 460 i would start there if its going to be a drag car. in order to make the kinda power you can with a big block out of a small block you wouldn't want a budget. 460 can make hp cheaper then your 302's or 351w.
mine :D 1989 notchback LX, no AC, no powerwindows, nothing, all from factory. I only have powersteering and electric mirrors lol I have the cheap small seats, no wing and no body kit too lol
No it doesnt the 85 has a 7.5
I think the notch is a great choice for weight as long as you don't want to haul your tires to and from the track in the car. If you want to do that go with the hatch. As far as the motor goes I don't think you want to try a 460 conversion at 17 unless you have some people who can help you and access to plenty of equipment. The 5.0 can be taken pretty far and if you're smart about your part choices 13's are realistic on a budget. I would go with the 90-93 notch since the speed density system is not a fan favorite and the 90-93 have the mass airflow that is so popular. That's just my opinion though, take it for what it's worth. I'm the idiot who drag's a heavy convertible.
86' was the first year ford the 8.8'..........correct.
If you go all-out drag car then don;t even worry about EFI (SD versus mass air). When you say budget, carbed is much cheaper. Just find a good and staright-bodied early 80's notch. That way you get the car for cheap, and anything else you will need to replace is an excuse to upgrade it bigger and better. I also second a 460, it will give you bar far the most headroom to build it up. If the budget is ever right, the 514 stroker is ridiculously quick. I know a guy that has one in an older T-bird running high 9's, all engine :)
I am pretty sure the 1985 GT 5-SPEED had an 8.8 in it, for a drag car get any 8X-93 4 or 6 cyl. car most the time there stright and cheep and you can find them in good shape sometimes with good paint and to do it cheep you can get C-4 AND 8.8 at junk yards pretty cheep. gut car i mean gut it. find a used 5.0 and go
