Big block swap
bagel77
42
Okay I hope I am in the right section. I have a 93 notch and I am thinking of putting in a 429 Big block. I have a few questions I am hoping to get answered. Can I still use the power brakes? power steering? Should i replace the K member? Motor plates vs motor mounts...and where can I get the motor plates? and any advice would be great. thanks
power brakes: yes, im using the stockers
power steering: yes, im using the stock pump and rack
K member: im using the stock 5.0 k-member
motor mounts: for cheap and effective/easy, use the FRPP swap mounts, oil pan and pickup, comes with dipstick too
Anymore questions lemme know....
I have a more recent pic than this but yes it can be done cheap and make a s**t load of power:
Wow I didn't know the power brake booster would clear my 91 notch (drag car only) has the manual brake conversion and I didn't the the valve cover would clear the brake booster. You don't have to run a motor plate or a aftermarket k member but I would recomend a k member. There isn't a bunch of room down there evan with a tubular k. I have seen some people run spacers in between the k member and frame to lower the k member. I don't know what this does to the suspension geometry but it allows the engine to sit lower in the car giving you more hood clearance.
big block header
Okay i was hoping to find some one that knows where I can get big block headers for this swap that will work with a stick...also looking for info on the bell housing for this swap thanks.
