Let me start by saying that the car wasnt acting like that last summer after we put the engine back in with H/C/I. It's in the end of the summer that this problem started. The car always had an unstable idle since the swap but I was expecting this. In the middle of the summer, I decided to put an Accufab adjustable fuel pressure regulator to help me not run lean when I'll be on the nitrous. First it was ok. Suddenly a few weeks/days after, the car was losing fuel pressure bad. Lets say I was setting it at 38psi vacuum on after the start, well after a run at the track, or 15minutes after a little cruise in the neighbourhood, the fuel pressure would be at around 29psi. So I'd raise it to 38psi again then run it and shut it down. Next time I start it, the pressure would be at something like 48-49psi vacuum on again.. So I'd lower it again and the same pattern has happened ever since. So I thought it was a bad afpr. I put the stocker back on, which was working fine before I removed it. Pressure would be at 28psi max and even lower. That sure wasnt normal. So I put the afpr back on and the same thing was happening. So then I thought it was a bad fuel pump. So I installed a 255lph brand new Walbro in there last weekend and same results. Now lets look at my fuel components. I have a fairly new fuel filter, 24pds injectors which have about 500miles max on them, new Accufab regulator, new fuel pump...
I thought that my EEC Tuner was the problem but after trying the J4J1 tune which should make the car run way better (not necesserally stronger), I had the same problems. I'm thinking the problem is not the tune anymore.
From what I know, I have the stock o2 sensors on there which would have about80 000miles. Could this be the problem ? What do you think about it all ?
Sorry for the long post guys but I'm getting a little desperate
Any help would be really appreciated again..
Mario
Mario
Come on guys
I had that vacuum leak propably since I took the car out this year...So my problem might be solved...I'll know tomorrow when I drive it and check if the fuel pressure is still all over the place, even after the install of my 255lph fuel pump.
